la Delta 3, un nouveau black sheep d'Ozone
mdr la Delta 3, un nouveau black sheep d'Ozone
Message  jmvdbk le 7/3/2016, 09:31
https://www.theparaglider.com/the-return-of-the-black-sheep-152
Comme toi Vinc, Ozone est la marque que je préfère pour ses innovations et son tempérament ...
après Mac Para
Nombre de messages : 7546
mdr Re: la Delta 3, un nouveau black sheep d'Ozone
Message  eric le 7/3/2016, 16:54
Rien n'est simple et tout se complique! scratch la Delta 3, un nouveau black sheep d'Ozone 43827
Nombre de messages : 1455
Message  clou de base le 7/3/2016, 19:30
Après le shark noose et le black sheep, la Delta 3 et la Zeno vont faire office de Loups dans la bergerie... la Delta 3, un nouveau black sheep d'Ozone 150406
Nombre de messages : 1754
Message  jmvdbk le 9/3/2016, 08:32
complément d'infos :
Questions for designers...
Hannes Papesh Interview 5 March 2016 .
Ziad- What’s your opinion about: "Softer leading edge do collapse often but they also recover faster and smoother, harder leading edge with a smaller AoA are very resistant but the collapses are more aggressive".
Do you agree? Or not... And why?
>>>>Hannes: We're dealing with that issue since mid of the 90’s. During the X-act development we were trying to find an airfoil which is collapse resistant and in the case, collapsing very soft and unspectacular.
As "to collapse" is a fundamental issue of the safety concept of a paraglider, this scenario should be very well predictable.
During the very intensive discussion about folding lines (see attachment) I've been arguing with the "dynamic history" of a collapse: the airfoil should deform, loose air and fold in the middle, to create a soft collapse. In this procedure the static weak points are important. They are given by the suspension points and the airfoil shape (and some internals maybe). When you mount folding lines on new suspensions (where there is no load during normal flight), you're faking new static weak points.
So we should spend some engineering and development effort to find an airfoil / solution that can do both: to be collapse resistant AND collapse soft and recover easy.
- Not just make "a quick cheat".
- Some in the scene are specialists for that, as we all know!
Ziad- Do you believe for instance that in order to see the real thing, the exact collapse in each individual glider regardless of their construction is to remove the test pilot ability to 'pull' the A's...
Hannes: Pulling the A's is good.
Sometimes it's not possible without mounting some separate lines (in case of an A/B fork).
Important is, that you pull on a suspension point, which is highly loaded during normal flight.
Experience shows, that the static weak points in real flight are between the suspension points: there the airfoil kinks in the case of a collapse deformation.
The simulated collapses should show the same deformation behavior as the real flight collapse.
Putting force on the airfoil further in front does enlarge the "deformation arm": resulting in softer collapses.
Ziad- Another idea could be to send a paramotor or some machine to create heavy turbulence that passes exactly 10 m in front of the test pilot over a lake... That way it will be clear on the videos how much the glider endure the collapse and how it will react.
- Do you think that this could be an evolution for future test houses ? Can you comment on that please ?
Hannes: It is not easy to create the standard rotor.
And will be quite hard to do: but that kind of testing could offer some more real life results.
The general problem is the exclusion of cheating actions.
We all have had airfoils which were flying fine and collapsed late. But they showed a very nasty and hard collapse behavior.
But you need really some "cheating creativity" to get the idea to mount folding lines far in front to get softer collapses.
With that technique you can get every airfoil look nice.
Because of that possibility and the very bad experiences of cheating by one manufacturer, the WG6 working group decided to limit those folding lines (invented by the same manufacturer) to the D class.
My philosophy (specially in the low classes) is to have a wide "green area". No special "best case scenarios / techniques" are needed. The wing should behave fine however the collapse is produced.
>>>>Luc Armant answer to the question:
Z- What's your opinion about : "Softer leading edge do collapse often but they also recover faster and smoother, harder leading edge with a smaller AoA are very resistant but the collapses are more aggressive".
Do you agree? or no...and why?
Luc: I disagree. I don’t see that at equal speed airspeed or AoA. from equal speed, fragile profile can easily have much worse recovery than more solid one. There is no strong rule here. Add to that the fact that collapsing is always more dangerous than not collapsing. In Ozone, we are searching for the best “real safety” design. We want gliders that we assess will be the safest to fly for pilots making cross country. We don’t want to compromise that.
Ziad- What's the benefit that a Delta 2 pilot will get flying the Delta 3 in order to disregard the certification at accelerated mode?
Luc: Best benefit for a Delta2 pilot, should be slightly higher speed and more performance at speed. We will not make anything special to try to convince pilot about recovery and EN rating, apart from a notice trying to explain things. Like usual, we will release our product and the pilot will make their choice. But again, we know that if we release it EN D we would for sure lose sell because many pilots still think that EN rating is their best way of knowing which wing to buy regardless of what the manufacturer is even recommending.
Z- The Delta 2 and Alpina 2 are still in personal view 'legends' in the C category. Many new C's that came after were more difficult to handle in rough air, except the Carrera plus. Was this only related to the back positioning A's on the leading edge ?
Luc: Of course not even though it’s an important one. There are a lot of other parameters. Too much parameters ! We believe that Aspect Ratio is one of the strongest one .
Ziad: Now seeing that the Carrera plus has similar performance or very close to the Alpina 2, Delta 2,
that GIN aimed for a B certification as a marketing strategy that could lead to larger sales.With the D3 going in the D category, OZONE is going on the exact opposite way in marketing strategy. Which leads to the question:
With the D3 certified as an EN-D, how will Ozone convince the Rush 4 pilots to move on the D3 ?
Luc: That would not be marketing strategy. We know we would lose significant sell because of that. But that’s the way it is. Good products are our priority.
Message  berni3d le 9/3/2016, 10:26
Je ne savais pas qu'on était sur un site anglophone geek
berni3d
berni3d
Nombre de messages : 1682
Message  jmvdbk le 9/3/2016, 11:27
le monde est ainsi fait, je n'y peux rien.
L'anglais est la langue ou il se dit le plus de choses intéressantes, puisqu'elle a, la plus grande audience.
L'homme a des ressources et sait s'adapter
... sinon il y a google translate la Delta 3, un nouveau black sheep d'Ozone 62400823
Message  eric le 9/3/2016, 13:39
Deux points de vue opposés, à peu près également partisans, plutôt pas mal argumenté par Papesh, pratiquement pas par Armant qui se contente de dire qu'il à constaté qu'il avait raison et que ses ailes volent bien (ce que l'on ne peut pas lui contester). Dommage que le point de vue Ozone ne soit pas mieux défendu, on reste un peu sur sa faim car le sujet est passionnant.
Message  jmvdbk le 9/3/2016, 15:05
Hannes Papesh est le concepteur des ailes Nova depuis 25 ans
http://www.voler.info/media/news-nova.pdf
